NEW! KATECH High capacity LS oil pump
Old Jul 15, 2011 | 02:42 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Default NEW! KATECH High capacity LS oil pump
New for 2011 Katech has added another oil pump to it's lineup. The new pump has 23% more capacity than the KAT-A2390 pump. Like the previous pump, it is also blueprinted and CNC-ported.
-Brand new G-Rotor oil pump
-23% more capacity
-CNC-ported oil inlet
-Strict procedures which assure ultimate quality
-Includes heavy duty oil pickup tube o-ring
In stock now! Order online http://store.katechengines.com/high-...pump-p272.aspx
Old Jul 15, 2011 | 03:24 PM
87silverbullet's Avatar
How would this pump compare in performance or what separates it from a Melling or a ported ls6 from one of the other sponsors?
Looks like a real good pump.
Old Jul 16, 2011 | 09:34 AM
GTO1_OHIO's Avatar
So more volume then the stock pump but what about pressure? Stock or higher?
Old Jul 16, 2011 | 11:29 AM
cutlass_455's Avatar
Is the outlet o-ringed??
Old Jul 19, 2011 | 11:25 PM
ta02zx10r's Avatar
does it fit under the timing covers without modification?
Old Jul 20, 2011 | 08:30 AM
LS1TECH Sponsor
This pump has a 23% larger gerotor than an LS6 pumps. I can't compare it to a Melling.
Stock pressure unless you use our shim to bump it up by about 10psi.
No.
Yes.
