Oil pressure question
Old Jul 25, 2011 | 06:46 PM
5LTRETR97's Avatar
Exclamation Oil pressure question
I was wondering if an ls1 needs to have the stock oil pressure sensor from the harness in order to start or will an aftermarket one work. Thanks.
Old Jul 29, 2011 | 12:41 AM
CAMSTER's Avatar
Default Pressure
You can add an after market gauge, but don't remove the ecm sensors.
Old Jul 29, 2011 | 11:30 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Yeah I would try and stick with the stock sensors because the computer will have an easier time reading that sensor.
Old Jul 29, 2011 | 12:17 PM
mike171562's Avatar
It will start and run with no oil pressure sensor connected at all
Old Jul 30, 2011 | 02:52 AM
Reed35's Avatar
Thumbs up
Agreed.
Old Aug 3, 2011 | 07:51 AM
CAMSTER's Avatar
Don't try that with a drive by wire
Old Aug 3, 2011 | 12:28 PM
1A Dan's Avatar
unless my setup's different, the ls1 and lm7 i had did not have a pcm-related oil pressure sensor; it was strictly for the gauges only. drive by wire may be different though....
By Brett Foote | 2026-06-04 05:00:17
