What rings should I go with?
Old Jul 27, 2011 | 04:47 PM
rossi89's Avatar
Default What rings should I go with?
The only thing left to buy for my bottom end is rings. I have a 4.030 lq4 that I am going to run about 12-18 pounds of boost depending on the power it makes. I have diamond 15cc 4.030 pistons. What rings do you guys recommend. Any input would be helpful. Thanks....
Old Jul 28, 2011 | 05:24 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Diamond has a steel top ring set for those that will work nicely. You can also buy it as a Total Seal ring set and probably save a few bucks.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 29, 2011 | 08:48 AM
CAMSTER's Avatar
Default rings
Call Total Seal, tell them what you are doing, they'll tell you what you need.
Old Jul 29, 2011 | 09:24 PM
rossi89's Avatar
Ok thanks a lot!
