Internal specs
Old Aug 2, 2011 | 07:40 PM
6.0monsta's Avatar
Default Internal specs
Is the only way to find build specs of a motor to tear it down and do measurements? Things like cam specs, compression, bearing clearances, etc.
Old Aug 2, 2011 | 10:50 PM
KCS's Avatar
KCS
Moderator
You can find cam specs with a degree wheel which does not require teardown. The rest of the stuff does.
