need arp main-rod-head stud torque specs
Old Aug 9, 2011 | 09:20 PM
mattz06's Avatar
Default need arp main-rod-head stud torque specs
lsx block, callies crank and compstar rods,with arp main studs and arp head studs, arp 2000 rod bolts. need to know torque specs
rod bolts?
main cap nuts?
main cap arp side bolts?
arp head nuts?
thanks!!
Old Aug 9, 2011 | 10:54 PM
MattSapp95_T/A's Avatar
75 ft lbs on the rod bolts
Mains are 60 on the centers nuts and 50 on the outer nuts and I think 22 on the little ones
Don't know about the heads
Old Aug 10, 2011 | 05:04 PM
COPO9560's Avatar
Make sure to use ARP's lube or the torque readings will not achieve proper stretch.
Old Aug 10, 2011 | 08:30 PM
S10xGN's Avatar
rod bolts?
main cap nuts?
arp head nuts?
thanks!!
Ya know? All this stuff is available straight from ARP's site...
Old Aug 12, 2011 | 12:03 PM
slt200mph's Avatar
Why not just call ARP on the phone their tech number is 800-826-3045. When in doubt talk to the manufacturer. They know for sure. Lots of the people on here have no clue at all or dispence incorrect info. You can do it online but I prefer speaking with a real human being...
Old Aug 12, 2011 | 02:16 PM
Randy WS6's Avatar
There are different type rod bolts that ARP puts in the rods, like the series 2000, L19 etc.. so make shore you have the right specs for the right bolt when you torque them, so you don't stretch or brake them.
