valve?
Old Aug 15, 2011 | 11:42 AM
boosted95's Avatar
Default valve?
I have a set of 5364 heads, is there a way to tell if they have hollow stem valves or sodium filled ones without taking them out? if not do you just weigh them?
Old Aug 31, 2011 | 09:11 AM
A_VAS's Avatar
weigh them to be sure. Hollows will be 91grams or so
solid around 120grams
Old Aug 31, 2011 | 03:15 PM
72VenturaII's Avatar
Here's an old thread that might help:
https://ls1tech.com/forums/generatio...omparison.html
Old Sep 24, 2011 | 12:38 PM
boosted95's Avatar
thanks guys
Old Sep 24, 2011 | 01:26 PM
KCS's Avatar
KCS
Moderator
The LS3 valves are fully machined, so the valve face in the chamber is smooth. The solid L92 valves have a rough "as cast" surface on the face of the valve.
Old Sep 24, 2011 | 03:18 PM
JS01's Avatar
The L92 valves are 107g.
The last LS3 valve i weighed I believe was 88g.
Old Sep 26, 2011 | 07:28 AM
boosted95's Avatar
well i bought some ls3 heads and i thought i heard they can have sodium filled valves or hollow stem. So i was trying to figure out if i needed to upgrade them or not since im building a high reving boost motor.
