MY LS3 Build/pics inside
6.2ls block w/stock bore and just polished the crank std.std.
scat pro i beam rods
SRP pistons
new LS3 heads w/hollow valves.. just polished the combustion chambers
stock 2010 camaro ss camshaft and rocker assy, from slp
comp cams single bolt double roller chain
new ls lifters
new L92 intake assy w injectors
all of the external components i got from a 4.8ltr that had a cracked block, i gave $100 bucks for the entire engine
before installing a new PerformaBuilt Level2 trans will be purchased..
