LS7 rods into a 5.3 block?
I am currently trying to learn the ins and outs of LS engines. I have worked on these engines for years as far as driveability in stock form,ect. Now I would like to play with them and learn more about them. Recently I was given a set of LS7 titanium rods and i also picked up a 5.3 engine. My thought is to put the 5.3 into a 63 Chevy II coupe that I have.
I would like to know if these rods could be used in this engine and what mods I would have to do to make it work. I am planning on running this car on the street and at the drag strip. I would like to stay with the fuel inj and not go with carburetion. Any info would be much appreciated. I realize that these rods may be a bit overkill for this engine. I'd like to make 500hp from this engine and be able to say it is just a little ole 5.3.
Please help me with this. thank you Jim Last edited by jxnslotcar; Sep 28, 2011 at 08:11 AM.
These rods would be great for a NA 427 but that's not what you are working toward. The replacement value of these rods at a dealer are signficant - hopefully you can recover a good portion of what they would cost new.
Someone mentioned I should sell them and maybe I should-use the money towards cam,studs,intake,ect as i could probably make 500 hp pretty easily with this engine by just getting heads ported,changing cam,intake. I'd like to know what all my options are before jumping headlong into this. I need to take the time to read thru lots of threads. Lately I have been working and then going to work on the race car to get ready for a big UMP race this weekend at Hartford Speedway.
The TI rods really are best fit in an original LS7. Crank bob weights and pistons all designed around light weight rotating mass. Great engine but steel rods would be stronger if a blower, turbo or big nitrous hit are used.
Starting with a 6.0 or 6.2 will put you way ahead of a 5.3. 500 hp at the flywheel can be made with mildly ported stock heads, cam change and good intake. The larger bore will open many more options for heads over the 5.3 making it a far superior choice. 5.3 is popular with turbo guys because they are pretty reliable and are very cheap to buy used.
As far as the Ti rods out of the LS7, I am going to sell them or maybe trade them towards parts for this engine. Maybe a set of heads or a cam,ect. I am going to stick with the 5.3 as I already have one sitting on an engine stand.
Does anyone know what is the optimum setup for one of these engines? I have heard that the heads that come on the 5.3 aren't bad but wondering if there might be a better one to use? LS3? and as far as the cam,is it better to go directly to Comp or one of the cam companies or is it possible to find one used on here and if so what would be the best cam for this engine? I am sorry as I realize I am asking kinda vague questions but trying to get my feet wet so as to narrow down the choices and maybe get the correct parts the 1st time instead of buying or trading for parts,testing them and then getting something else. I still need to decide as to whether or not to go carb or EFI. I would like to get the equipment so as to be able to do my own tuning. I do have what is know as an I Flash from Standard but not sure whether that could be used as a tuner or if it is strictly something to be able to download stock calibrations from GM,ect.
