lq9 ls7 or ls9 cam?
Old Oct 6, 2011 | 02:22 PM
oddwraith's Avatar
^^^well the price is right for that cam but even I think that would be a tad small for six litres, and I LOVE small cams. You never know though, that cam has seen some pretty dynamic applications over the years with some great results. I'm just not sure about it for your setup.
Old Oct 6, 2011 | 08:01 PM
87silverbullet's Avatar
Originally Posted by massillongoat
that set up is really close to what i have going on...I have a wet kit....it has stock 317 heads on it for now....vararam yank 3600 stall 3.46 gears..10.53 at 133??? slicks i'm assuming?>
Yes, slicks.
i was really looking at the 02-04 z06 cam because of the split....207/218 that would be prime for nitrous
If you are not spraying more than a 250 shot you don't need to look at certain duration numbers and say they are good for nitrous. Plus, you are a little off I think, its 204/218
If you are going to put a z06 cam in a 6 liter truck motor you might as well put a turbo in front of it too because that is what most forced induction guys do as their cam of choice.
Old Oct 7, 2011 | 02:48 AM
massillongoat's Avatar
eventually after forged enternals...it might not be a six liter for long...been looking at stroker kits reason being why i havne't bought a cam yet,...been looking at 408 stroker kits but i dunno...i"m tired of messing with it reason why i wanna just put a small cam in it and be done...besides the tr224 what do you suggest?
Old Oct 7, 2011 | 10:01 AM
oddwraith's Avatar
TR224 would be a good way to go, other than that there are tons of threads about cam choices and which one for what application. Good luck!
Old Oct 7, 2011 | 10:10 AM
honestly that might be a little small for a six liter...but I dunno i'm gonna look into it
Old Oct 7, 2011 | 10:35 AM
oddwraith's Avatar
Well you said you were looking at an ls6 cam here, I'd go with a comp 212/218 114 over that.
I said this about the ls6 cam.
Now you say that the TR224 is too small? I'm a little lost lol
Good luck!
Old Oct 9, 2011 | 09:01 AM
Ragtop 99's Avatar
I"m gonna be running nitrous and I want it to be sleeper for sure that's why I don't want a tr224 or anyting on a low lsa..i'm looking for like a z06 cam or something along those lines
C6 Z06 will be a sleeper cam.
Any cam you can spec with -8 overlap will be a sleeper at an 800 rpm idle.
Go with a 218/230 116 +2 on EPS or XFI lobes. It is -8 overlap. It will have good low end throttle response, make more power than a Z06 cam on or off the bottle, and has plenty of exhaust for the spray.
