ls7 stroker kits
Old Oct 23, 2011 | 11:59 PM
Bowlson's Avatar
Default ls7 stroker kits
Where can I get a good stroker kit that can handle up to a 1000 hp
Old Oct 24, 2011 | 12:59 AM
My6speedZ's Avatar
Texas Speed has what your looking for, go on their website and you can look at them and up grade the components to the desired horsepower level and see the adjusted price. They are also a sponsor and you can call them if you need any tech support before your purchase.
Old Oct 24, 2011 | 08:39 PM
S10xGN's Avatar
The LS7 stroke is already at 4.00", the most you'll be able to get is another 10 cubes by going to a 4.10" crank. Not worth the $$$ or the durability problems...
Old Oct 25, 2011 | 05:00 PM
My6speedZ's Avatar
I totally missed that, i guess i was thinking of the .30 over 440 kits
Old Oct 25, 2011 | 07:49 PM
KCS's Avatar
KCS
Moderator
.030" over still doesn't make 440ci, more like 433ci, and you probably wouldn't want to go that far oversized with the stock sleeves if the goal is 1000hp.
You probably wouldn't even want to use the stock sleeves for 1000hp anyways. At the very least, I'd use something like a MID sleeved block.
Old Oct 26, 2011 | 06:44 AM
My6speedZ's Avatar
If you buy the ERL superdeck in block form in a 434 and its good for that kind of power. The turbo extreme shortblock is the 6 bolt blocks and cost $7500, block is $3000
and yes 440 is i believe 4.125x4.100?
Old Oct 26, 2011 | 07:36 AM
delphigto's Avatar
Call sean or seth at erl they are great to deal with and would be happy to help you. Ohio boys run erl blocks well over 1000 hp.
