ls2 head question(messed up)
Old Oct 26, 2011 | 02:10 PM
firetruggy's Avatar
Default ls2 head question(messed up)
Ok so very new to putting these motors togeather. I bought a ls2 short block and 243 heads, I put the heads on and relized put them on the wrong side, they looked identical except the plug and sensor, I called GM and guy said they had same part number can I just swap the sensor to the driver side and put the plug in the pass side and call it good, or do I need to get new headgaskets and switch them thanks Ryan I tried to search and came up with nothing
Old Oct 26, 2011 | 02:39 PM
BimmerLSX's Avatar
I always thought if you didn't fire it and get it hot you can reuse them. Depending on the bolts you used you would have to replace them. I'm not 100% tho.
Old Oct 26, 2011 | 05:52 PM
firetruggy's Avatar
I used stock oem head bolts have not fired it up yet, so the heads are specific to pass and driver side.
Old Oct 26, 2011 | 06:49 PM
WKMCD's Avatar
They're interchangeable. Just swap the hardware.
Old Oct 26, 2011 | 10:05 PM
firetruggy's Avatar
ok cool thanks alot I feel way better already changed sensor and plug over.
