how much do clearances open up at temp??
Old Nov 9, 2011 | 12:00 PM
rennocneb's Avatar
Default how much do clearances open up at temp??
Wandering how much mains open up in the aluminum blocks as the engine comes up to temp? I have way lower hot idle oil pressure than i think i should. My build sheet shows all mains .0018 to .0020 rods are all .0022 to .0025 and it drops from 55psi cold idle to 25psi hot idle. Water temp is right about 200, oil temp is 215ish
Old Nov 9, 2011 | 04:04 PM
Pumba's Avatar
What oil pump are you using?
Old Nov 10, 2011 | 12:36 PM
rennocneb's Avatar
melling 10296 with the red spring.
Old Nov 10, 2011 | 03:27 PM
Gray86hatch's Avatar
I have heard you will gain .001 with heat in the motor. I belive this
I see 80 cold idle and 35 hot as soon as it is off idle it makes about 60 and at 7000 almost 100.
Tim
Old Nov 10, 2011 | 08:28 PM
crossbreed383's Avatar
What type of main clearance did you have in your motor this last time Tim?
I know you of all people should know what works after all your troubles
Thanks
Old Nov 10, 2011 | 08:44 PM
.002 now. .0024 on the rods.
First time the guy who did the machine work convinced me to set the mains at .027 he also made the main bore too big and lost the crush on the brearing. This time we made the housing bore as small as possible and ground the crank to fit.
Tim
Old Nov 11, 2011 | 06:50 PM
Pumba's Avatar
Melling makes two other LS pumps that have a higher volume output than the 10296 pump:
Because the LS block is aluminum you can have your main clearances almost double when the engine heats up.
