2007 ls2 questions/cam help
Old Nov 23, 2011 | 04:32 PM
cacmanjr's Avatar
If I had it to do over again, I would go with the 54-460-11.
Old Nov 23, 2011 | 04:35 PM
bad67ls's Avatar
seems like alot of lift for a cam only swap without flycutting, and its a 113+4 lsa...seems a bit wide for a carb app to me...
Old Nov 25, 2011 | 03:53 PM
chrisfrost's Avatar
Duration is more of a factor than lift is in LS's . But really the only way 2 b sure is 2 clay the pistons/camshaft . But I would say that if 1 of the earlier posters GTO with a cam in the 240's duration and he had no ptv contact then that cam in the 236 dur range that You should b just fine .
