LS7 intake on LS2 block?
Old Dec 2, 2011 | 03:37 AM
Fast GTO's Avatar
Default LS7 intake on LS2 block?
Can you use an LS7 intake on an LS2 block?
Found a good price on an LS7 intake but curious if it is the same sort of swap like going to an LS3 top end.
Do the LS3/L92 heads bolt to an LS7 intake or will I need LS7 heads? All if it going on an LS2 block in a 2006 GTO.
Old Dec 2, 2011 | 04:24 AM
yonerhottlt1's Avatar
Sorry, wont work buddy. You also need the heads and LS7 heads wont fit on an LS2.
Old Dec 2, 2011 | 05:42 AM
87silverbullet's Avatar
You can get the small bore LS7 heads from TSP and run them on there with an LS7 intake. I don't think you have enough cubes to run all that though.
Old Dec 3, 2011 | 01:38 AM
gnx7's Avatar
It would work if you resleeved it and ran LS7 heads
A better budget option is to simply run LS3 heads/intake. They work on the stock LS2 4.0" bore.
