Hutter Performance's 440 LSX.
Old Dec 11, 2011 | 11:53 PM
IDRIVEAG8GT's Avatar
Default Hutter Performance's 440 LSX.
Did a quick search and didn't come up with much, however I figured some of you might know.
What heads are used here, and what sort of grind is on this cam?
Thanks.
http://www.youtube.com/watch?v=y_6txu-ytlQ
Old Dec 12, 2011 | 12:46 PM
Sorry guess I should've clarified,
Are these Cathedral Port heads or LS3 style,
And what's the approximate grind on this cam? I was hoping Bobby Lashley might chime in because I think he has done some work with Hutter in the past.
Old Dec 12, 2011 | 12:57 PM
SDB's Avatar
SDB
Wilson sheet alumimum intake, I would "assume" MAST/MOZEZ heads. The engine has run the fastest NA times so far...2005 GTO 7.709 @ 172.99. NA. No boost. Wow.
Old Dec 12, 2011 | 01:12 PM
It's a badass indeed, that's why I wanted more info. I emailed them about it, but they gave no specifics, except that it would cost 40k to build. Especially considering it makes power to like 9500 rpm!
Old Dec 12, 2011 | 01:15 PM
chris@hps's Avatar
Not sure what heads either, however they are NOT the "MOZEZ" heads. The Mozez heads use a SB2 style valve cover and those are a standard LS style cover. Awesome N/A Power for sure!
Chris
Old Dec 12, 2011 | 01:39 PM
I wonder..... The video says that Hutter did their own port/polish job on the heads. So I imagine it'd be a GM cast head (style unknown) or even a MAST head that somehow they twacked out even more, although I don't see how that's possible.
What theoretical flow would you have to have on the heads to develop that sort of power? Over 400cfm?
Old Dec 12, 2011 | 03:46 PM
SDB's Avatar
SDB
I would imagine 450+cfm at least....
$40K to build and lots of $$$ to maintain....I can imagine you dont get many passes on valve springs on a 10,000+rpm set up!
BUT..to run 7.7x's with a NA small block is priceless! However, you can get get a streetable big block pump gas motor that makes 1000hp/865 torque (632 cube Shafifroff motor) for $22K, and a race gas motor for $15k that makes a little more power).
Old Dec 12, 2011 | 03:56 PM
LS1-450's Avatar
Hutter used to build engines for NASCAR. Call 'em. They'll answer your questions. If you're out of state & want someone to keep an eye on an engine build for you, Hutter is only 25 min. from here; just let me know. BTW, Ron Hutter is a well respected professional engine builder. His kids ain't too shabby either.
Old Dec 12, 2011 | 11:45 PM
Didn't know that. Like I said, I e-mailed them about this motor and they were reluctant to give up specifics. I don't blame them however, it's big, badass, and the best in the N/A world.
Thanks for chiming in man.
Old Dec 13, 2011 | 09:31 AM
MHutter519's Avatar
It's not quite as expensive to maintain as you might think. We changed valve springs once a year, when we went through and checked the bearings, etc... after the season. We do have this engine for sale right now - the GTO went to a buyer in Australia, but he bought it as a rolling chassis. So although this would be a pretty expensive engine to duplicate new, we have this one priced somewhat lower (and are open to reasonable offers as well).
The heads are All Pro with CFE/Hutter porting.
Thank you for all the compliments in this thread - we work hard at making power here!
Old Dec 13, 2011 | 10:23 AM
Well I'll be damned, it was nice of you to join for what appears to be essentially for this thread. Now I can prod you with more questions about this motor
Back to heads, Being ALL PRO castings, I assume they're a special LS7 from them with some major work done. Can you post up some pics of your alls head work?
And cam, gotta ball park figure of how that puppy was ground?
Old Dec 13, 2011 | 12:53 PM
MHutter519's Avatar
I figured I was in a good position to contribute to this thread, plus help get the word out that the engine is for sale.
The heads are All Pro LS raised port castings. The CNC port work is by CFE, with a little hand work and valve job done here. Most of our head work is done that way these days - we have port shapes that Ron has developed that are CNC machined, and then he touches up as needed (which usually isn't much, if any). I'll see what I can do about getting some pictures up, but mostly what you'd be seeing is CNC work.
The cam is 282/288 @ .050, .775 lift. It's one of our custom grinds by Comp Cams.
Old Dec 13, 2011 | 02:09 PM
I'm certainly happy you decided to join. That thing is totally wicked!
Once again congrats. Would you consider an offer of 1000 cash, And a 6.0L truck block, LS3 heads, and my right nut? That is everything I have to offer!
Old Dec 13, 2011 | 04:34 PM
MHutter519's Avatar
Glad you like it - it's been a great motor for us! Even though the GTO is sold, we're certainly not done racing LS stuff and we have some new things in the works for next year.
Old Dec 13, 2011 | 07:58 PM
Cape T/A's Avatar
Awesome! Good to hear!
Old Dec 13, 2011 | 08:02 PM
RDeWild's Avatar
Cool engine!! What did your GTO weigh?
Old Dec 13, 2011 | 08:36 PM
My offer was declined :/ lol.
I think someone should go retarded and stuff this engine into one of those RCR SLC kit cars.
Old Dec 13, 2011 | 10:40 PM
dwill73's Avatar
WOW, I was thinking at least 20 degrees split in duration and .900 plus lift.
Old Dec 14, 2011 | 06:18 AM
MHutter519's Avatar
It was 2100 ready to go without driver weight, so just under 2300 with me in it.
Old Dec 14, 2011 | 07:27 PM
scphilli's Avatar
Very nice. EDIT: answered my own question!
