Cam Choice LS3 A4
Old Jan 6, 2012 | 07:36 PM
GONEB4U's Avatar
Question Cam Choice LS3 A4
I'm looking to swap a stock 2010 LS3 with a upgraded 4L70e trans. with a 3200 stall into my 1990 Trans Am. It will have stock exhaust manifolds going to a y pipe merging into a aftermarket cat back system. This car will be full weight (3600) and be driven as much as possible with the occasional trip to the drag strip. I want this to be a very aggressive street car. My only upgrade to the engine will be cam and Patriot double springs. I recently got a Comp Cam 227/243 .614 .624 on a 114. I was wondering what you guys think this should make to the wheels for hp through a (3.73) 10 bolt rear. Would you use this cam or go with another one? Which one? I know the stock exhaust manifolds are a big bottle neck, but the cost for swap headers do not fit into this swaps budget. In addition this car might get sprayed with a 150 hp wet shot.
Old Jan 6, 2012 | 07:45 PM
DietCoke's Avatar
440-450 rwhp through the auto. That would probably dyno 470ish through a 6sp.
Edit: Just saw no headers. You wont even break 400 with manifolds on. Too much cam... reversion issues... blah blah.
Old Jan 6, 2012 | 09:20 PM
No Hope's Avatar
There is nothing wrong with that cam, I would get a cheap set of mild steel headers. 450 would be the high end with a good tune.
No wet shot
Old Jan 7, 2012 | 10:58 AM
GONEB4U's Avatar
No wet shot
Point me towards a cheap set of mild steel headers that work in a 1990 Trans Am LS swap and I would be all over them. The problem is that all I can find are Hawk's for $650 and up.
Old Jan 7, 2012 | 01:42 PM
DietCoke's Avatar
http://www.hedmanhusler.com/1982-92-...S-Swap-Headers
http://stores.bulldawgmusclecars.com...x-1/Detail.bok
Gotta pay to play
Old Jan 8, 2012 | 09:55 AM
GONEB4U's Avatar
As for now I think I will stick with the manifolds. What do you guys think of this cam?
Old Jan 8, 2012 | 03:39 PM
DietCoke's Avatar
You'll be better off with a MUCH smaller cam if you arent putting headers on it. Bigger is not better.
Old Jan 8, 2012 | 03:46 PM
GONEB4U's Avatar
I'm willing to sell the cam and get another one if it will work better for my combo. Any suggestions?
Old Jan 9, 2012 | 09:10 AM
Patrick G's Avatar
LS1 Tech Administrator
That is a miserable cam choice for stock manifolds. The reversion caused by them will cost you dearly in power production. If you are for sure going to stick with manifolds, then you must choose a cam that will make your engine less sensitive to back pressure. Something like a 223/230 .610/.609 115LSA +3. That would work well on motor and on the spray.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 9, 2012 | 11:03 AM
87silverbullet's Avatar
If you can't shell out the dough for long tubes, Edelbrock shorties will fit in there.
Old Jan 9, 2012 | 11:28 AM
andrew69_04's Avatar
the hawks swap headers are a very nice piece for a third gen. Thats what i ran in my camaro when i built it. i know they are $$$, but like all stainless headers, they are definitly worth it. if your going to run manifolds, just keep the stock cam in the motor until you can afford LT's, then swap the headers and cam in at the same time and go.
Old Jan 9, 2012 | 03:02 PM
GONEB4U's Avatar
Thanks for your advice Patrick. If I stay with manifolds then I will contact you to get a cam speced out. The last one you speced for me worked awesome. Do you think the cam I mentioned above is ok if I bite the bullet and get headers?
Old Jan 9, 2012 | 03:49 PM
Patrick G's Avatar
It's still a ridiculous cam choice for an LS3 with headers. Way too much exhaust duration. A 227/234 113-114LSA cam would be a much better choice with headers.
__________________
