LS7 cam?
Old Feb 2, 2012 | 07:53 PM
jlay's Avatar
Default LS7 cam?
Guys, I have what is supposed to be a LS7 cam. The only numbers on it are
206/08 ENG
5527
Can any one verify what cam this may be? Thanks in advance.
Old Feb 3, 2012 | 10:06 AM
redtan's Avatar
Doesn't sound like an LS7, that's somewhere around 211/230. Not a hot cam or LS6 either
Old Feb 3, 2012 | 11:33 AM
jlay's Avatar
On another thread someone said it may be a england green cam. The vendor I bought it from told me it was a LS7 take out. I am about to start to assemble my motor and was making sure I had all of the parts together. When I started to look at the cam I noticed it was not the GM numbers on it.
I will try to post a pic later.
Old Feb 3, 2012 | 12:29 PM
L-EATER's Avatar
11 Second Truck Club
5527 is a LS9 cam. Similar in specs to the LS7 but from what I understand the LS7 is a 1 bolt and the LS9 is a 3 bolt.
Old Feb 3, 2012 | 01:42 PM
Wnts2Go10O's Avatar
ls7 cam is 3 bolt.
Old Feb 3, 2012 | 09:08 PM
jlay's Avatar
Thanks guys, doing some reading it looks like it is a LS9 ZR1 cam.
Would this work well with a n/a stock LS2?
Old Feb 3, 2012 | 09:27 PM
Wnts2Go10O's Avatar
boost, yes
n/a, eh..
Old Feb 7, 2012 | 06:30 PM
Mako77's Avatar
maybe in turbo setup
Old Feb 11, 2012 | 10:37 AM
Jablowme's Avatar
I have this cam also was trying to find out what it is forsure
but i find the number 12638427 for the LS9
is there a diff in cams LS9 and LS9 ZR1 ?
Old Feb 12, 2012 | 01:08 PM
jlay's Avatar
From the searching that I did the zr1 cam is the 5527
Old Feb 13, 2012 | 03:35 PM
PartsTaxi.com's Avatar
Closed ex-Sponsor Account
Yep, ZR1 LS9 cam. I have a bunch of guys running them in LS2/3 set ups.
You asked difference in LS9 and LS9 ZR1? LS9 only available in ZR1, Camaro and CTS-V have LSA engine which is different cam.
Thanks
Kevin
www.PartsTaxi.com
Old Feb 13, 2012 | 05:54 PM
Jablowme's Avatar
Thanks
Kevin
www.PartsTaxi.com
ok so the 5527 = ZR1 LS9
anyone have full cam card specs for it
Old Feb 14, 2012 | 02:01 PM
HoP's Avatar
HoP
Early 2006 is a three bolt late 06 to present is one bolt if I'm not mistaken.
Old Apr 20, 2012 | 01:18 AM
2002BLKTA's Avatar
Mine is a 2007 Z06 and it was a 3 bolt cam
Old Apr 20, 2012 | 04:06 PM
ringram's Avatar
I thought the specs were pretty much the same duration wise anyway, lift was down to rocker ratio. But maybe the LSA is different.
