big stuff 3 /lsx 7000 + rpm
Old Feb 3, 2012 | 02:42 PM
STROKER R/T's Avatar
Default big stuff 3 /lsx 7000 + rpm
just wondering who is using bigstuff 3 with lsx soild roller big rpm 8000 9000 ..what are you guys doing to measure crank signal ...like sensor /reluctor wheel ..front or back ..i been good to 7200 ..not so sure the signal will be good past that
Old Feb 3, 2012 | 03:30 PM
Patrick G's Avatar
LS1 Tech Administrator
The guys I've seen running over 8000 rpm have typically gone to a distributor and a Jesel belt drive. I'm sure there are more ways to skin a cat though.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 3, 2012 | 03:58 PM
true waiting on the efi guys (help ) lol
Old Feb 3, 2012 | 04:10 PM
vetteboy2k's Avatar
There seems alot of debate on this topic.
Our experience has been:
stock pcm shuts down around 8200+
bs3 with internal cam/crank gm ls7 block worked to 9000rpms with COP and no belt drive
We have seen a steady signal to 9500 rpms on the dyno with bs3 external reluctor/belt drive/ and COP.
Others have had a different experience. No 2 setups are equal so do your research and make an informed decision from a large sample of information.
Old Feb 3, 2012 | 04:40 PM
good info thanks a billion
Old Feb 3, 2012 | 07:45 PM
Gray86hatch's Avatar
plug in Holley efi 7500 is no issue
58x is better than 24 by design
Tim
Old Feb 3, 2012 | 08:24 PM
dr ls7's Avatar
I'm running a ls7 factory block that we will spin to 8000+ rpm. It's a sv1 carb with Msd front mount dizzy and crank trigger, Msd 7531 box . Should be on dyne within 3/4 weeks
Old Feb 3, 2012 | 09:16 PM
3 options now front mount reluctor with sensor 70/30 chance !!! big stuff owner tells me #1. .rip out block change reluctor on crank to ls7 covert all big stuff send in bigstuff $$ #2 or roll the dice my power falls off at 7200 rpm .#3 ..i dont like my options on all these
Old Feb 4, 2012 | 06:21 AM
I would look at the other systems avalible before pulling the engine appart. Others don't have issues with stock reluctors
Tim
Old Feb 4, 2012 | 08:53 AM
stock pcm year and what internal reluctor wheel 24 or 58 ?? please ?????
Old Feb 4, 2012 | 09:07 AM
vetteboy2k's Avatar
03 corvette, 24 tooth reluctor.
If ~8000 was my max rpm I would stick with all the factory stuff.
Old Feb 4, 2012 | 09:22 AM
with ya on that call lol ..it is 454 730 lift 11.7 com street /strip ..it will not rev to the moon ... lets see gimme a week
Old Feb 4, 2012 | 10:22 AM
pantera_efi's Avatar
Default Processor Speed vs Tooth Count
I have heard that John M. states the same thing about his BS-3, NO high rpm with the 60-2 (58-x) TW.
My ECU-882 family will run over 25K with a 58x (60-2) crankshaft Target Wheel.
The common knowledge is derived from processor speed vs tooth events.
Industry standard is 100mhz for the 60-2, the 164 he uses is 25mhz.
Thus when shopping for a system, check for processor speed.
Lance
Old Feb 4, 2012 | 12:02 PM
Lance
guess its like pentum #1 vs pentum #3 now
