rods caps question
Old Mar 19, 2012 | 07:54 AM
Mike Cordero's Avatar
Default rods caps question
If the caps were removed from the rods but didn't be marked to the correspond rod, it this a problem?
Old Mar 19, 2012 | 12:29 PM
Whistler's Avatar
Sawzall and Welder Mod
Stock rods?
Old Mar 19, 2012 | 03:02 PM
Originally Posted by Whistler
Stock rods?
Stock rods.
Old Mar 19, 2012 | 03:58 PM
JS01's Avatar
Originally Posted by Mike Cordero
Stock rods.
Not a problem then, they can be matched back together since each rod will be cracked uniquely.
Old Mar 19, 2012 | 08:18 PM
Mike454SS's Avatar
Yeah, every cap will only fit the right rod...just guess and check until you get them back together. When they make them, they are 1 piece and they etch a center line then snap them off at it...every one breaks uniquely.
Old Mar 20, 2012 | 06:43 AM
Thanks for the info.
Old Mar 20, 2012 | 05:23 PM
chrisfrost's Avatar
I believe they score each 1 a little differently also at least on the small sides as that seems to be where the most difference is from 1 to another .
