SDPC pictures of the newly revised LSX block
Old Mar 23, 2012 | 06:19 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Default SDPC pictures of the newly revised LSX block
The newest revision of the GM LSX Bowtie block has been released and we have them in house right now.
Main features of this revision are:
-Improved metallurgy that results in upwards of 50% increase in tensile strength throughout the block.
-Reinforced deck with strengthened water passages and bolt holes
-Revised cam oiling passages that allow clocked cam bearings to optimize camshaft oiling in the highest performance applications with huge spring pressures and high loads.
Here are a few pictures of the blocks (there is a thin layer of oil covering all machined surfaces):
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 23, 2012 | 07:09 PM
427's Avatar
427
Thank you GM (and SD)!
Kurt
Old Mar 23, 2012 | 08:49 PM
ws602's Avatar
What is the cost and what is the part number?
Old Mar 24, 2012 | 02:05 AM
Jontall's Avatar
The important question is, "did they fix the core shift problem"? The core shift in this picture below, is just horrible.
Attached Thumbnails SDPC pictures of the newly revised LSX block-lsxblockcoreshift.jpg
Old Mar 24, 2012 | 02:11 AM
bww3588's Avatar
That's not core shift...^^^that's a gm display block showing the range of bore sizes.
Old Mar 24, 2012 | 10:30 AM
Jimbo1367's Avatar
Then why does it look like the cyl.s on the left seem to be thinner to the left (looks to be bored off center)
Old Mar 24, 2012 | 11:51 AM
bww3588's Avatar
All of the cylinders in that picture are like that. The cylinder wall is thinner because of the bolt hole. If the camera was more centered on the block, you would see they would be thinner on the right side of the cylinder as well by the other bolt hole.
Old Mar 24, 2012 | 12:15 PM
19260093 is the part number for the newest revision. The price is $2295
__________________
Old Mar 25, 2012 | 11:12 AM
ws602's Avatar
I wonder how this thing compare to a RHS block?
Old Mar 25, 2012 | 12:36 PM
blackls1ta00's Avatar
i want one!!!
Old Mar 25, 2012 | 07:31 PM
RacerXLs1's Avatar
My next motor!!!!!!
Old Mar 25, 2012 | 08:30 PM
scphilli's Avatar
Heavier, stronger, half the price. All about trade offs
Old Mar 26, 2012 | 09:16 AM
Roger Blackmore's Avatar
Was the core shift problem addressed?
Old Mar 26, 2012 | 09:31 AM
I've posted what I know was changed. Obviously, we have not built anything with them yet since they are brand new. From what I see, I see a much better product so far.
__________________
Old Mar 26, 2012 | 09:38 AM
Thank You sir,
I have no first hand experience with this, but I monitor threads about core shift. Will be going with some kind of aftermarket block on the next build.
