ABSOLUTE best heads for stroked ls2 (COME ON IN)
Old Apr 9, 2012 | 07:56 PM
  #41
gectek's Avatar
For a head that would fit all applications like a beast, get Trick Flow.
Old Apr 9, 2012 | 08:40 PM
  #42
The1N_only's Avatar
Since you like to quote Pat G...
https://ls1tech.com/forums/15292549-post5.html
Old Apr 9, 2012 | 08:57 PM
  #43
gectek's Avatar
I knew about that post and thread as well. You are showing me nothing new. He had stock heads on it before, he went with Tony Mamo specials. There is no comparison there. He also went with an aftermarket camshaft instead of the stock one he dyno'd with as well as a cathedral FAST ported by Tony Mamo. Maybe you should read the comparo before you post it up all smug like.
With all those parts that are ALOT more money than the heads that came on there unported, you would hope they would show something. Hell he still had the DOD on there as well in stock form.
He made a blanket statement that is not entirely true either with the "it dynos higher than ported LS3 headed 6.0 combos". His made nearly 400 with just the stock cam unported heads and an out of the box fast. I am sure that 500 would be no problem with a cam that fit the heads, which he sure could do, a ported LS3 fast and ported LS3 heads.
Old Apr 9, 2012 | 10:37 PM
  #44
LSxPwrDZ's Avatar
Trickflow! Fastest LSx in the world runs 235's. Not seen any Mast stuff here locally run worth a damn. Same with tsp stuff.
