Eagle crank recall?????
MY QUESTION IS !!!! EVERYONE IS BACK ORDERED ON THIS CRANKS BIG NAMED SPONSORS BU THIS GUY HAS 10 EAGLE CRANKS INSTOCK ! WAS THERE A RECALL OR SOMETHING HERE ?
In the title you can clearly decipher 4.125 58 tooth then you look at the description and you see 3.622 24 tooth. So which one is it?
The part number ran thru eagle's site shows its a 4.125 crank and 58 tooth.
http://www.eaglerod.com/index.php?op...d=21&Itemid=32
What crank are you looking for? Plus how fast do you need it? Summit can get either crank shipped out by the 4/30. Jegs can get the 3.622 shipped out on 4/26
http://sdparts.com/category/cometic-mls-head-gaskets
As far as your crank, I personally wouldn't use an Eagle crank. Its just from personal opinion and experience. I use Callies exclusively.
http://sdparts.com/category/crankshafts
