Ring Selection: have choices narrowed down
Old May 23, 2012 | 04:25 PM
Wnts2Go10O's Avatar
Default Ring Selection: have choices narrowed down
I have my choices narrowed down but a question or 2.
Im trying to decide between the JE ProSeal and the Diamond ProSelect. i am seriously considering a napier 2nd ring but JE only has those with teh 1.2mm top and 1.5mm 2nd ring.
question 1: is there anyone the sells a 1.5 1.5 3.0 set with a napier second?
question 2: what sort of oil ring would be best in this sort of ring pack??
basically, my whole setup is in the sig but is also an update/fine tuning of the engine. the better rings probably wont yield a lot but.. every little bit of efficiency and such helps
id also like to thank machineistone for helping me out via pm's.
Old May 23, 2012 | 04:46 PM
AES Racing's Avatar
Neither JE or Diamond make piston rings, that's not a knock against them.
Total Seal and Akerley Childs are who I deal with for piston rings. Both those companies sell 1.5x1.5x3.00mm with Napier 2nd ring.
If you need a set feel free to contact me.
Old May 23, 2012 | 07:03 PM
Wnts2Go10O's Avatar
i know they dont but well.. details details.. who actually makes these companies' rings anyways?
im trying to find info on the A&C rings but im not having any luck.
Old May 26, 2012 | 03:02 AM
gnx7's Avatar
Total Seal is a quality ring manufacturer. Check them out for sure.
Old May 26, 2012 | 10:50 AM
KCS's Avatar
KCS
Moderator
Did you try Hastings?
