Clearance Measuring
Old May 25, 2012 | 03:08 PM
Wnts2Go10O's Avatar
Default Clearance Measuring
getting block back (finally) very soon so i wanted to ask (after a search mind you)
all i have is a dial gauge in .0005 increments, a set of 6" calipers, and 3-4 sets of feeler gauges (lol). plastigauge seems to be out of the question. so.. the question is.. would i be able to do this assembly with the measuring tools i have (accurately)? this is for the budget build i am doing.
Old May 25, 2012 | 05:20 PM
crainholio's Avatar
No micrometer?
Old May 25, 2012 | 05:37 PM
Wnts2Go10O's Avatar
Originally Posted by crainholio
No micrometer?
nope, unfortunately
Old May 25, 2012 | 06:05 PM
3rdCoastPowerSports's Avatar
Since you dont have all the right tools why dont you want to use plastigauge to check?
I know it is NO WHERE near as accurate but if you use Plastigauge properly it will tell you if you are in the ballpark
Old May 25, 2012 | 06:43 PM
RezinTexas's Avatar
this is the one I got
http://www.amazon.com/dp/B0006J42CW/ref=biss_dp_t_asn
Old May 25, 2012 | 06:50 PM
Wnts2Go10O's Avatar
actually, question, why would calipers be inaccurate for measuring outside diameter?
well, after a bit of reading it looks like plastigauge can be WAY off even when used correctly
Old May 25, 2012 | 07:41 PM
Calipers are not a replacement for a micrometer. too easy to mess up the measurement (i.e twisting, squeezing).
Before i bought a mic and bore gauge I would have my machinist measure the clearances then i would verify them with plasti... it was always right there with the machinist measurements. now i have a dial and mic so no more plasti
