na ls7 build... is sleeving needed
Old Jul 11, 2012 | 10:28 PM
djfury05's Avatar
Originally Posted by MrEracer
They look like Diamond pistons. I'll give you $1000 for your block.
MrE
really... Texas-speed lists LS1 blocks at $1100...
Old Jul 11, 2012 | 10:48 PM
baggins's Avatar
Pistons are custom diamonds for etp ls7 heads.... and nice lowball on the block
Old Jul 12, 2012 | 12:29 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default LS7 blocks
Well, I have three cracked LS7 blocks here to repair at the moment. Any detonation at all will crack a sleeve and block. I have had shops send me cracked blocks from engines just getting a dyno tune to squeeze a bit more power out of the engine.
It is a lot cheaper to sleeve the block prior to the build than to build the engine twice.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jul 12, 2012 | 01:46 PM
5w20's Avatar
I would take RED's and ERL's advice.
Old Jul 12, 2012 | 02:10 PM
baggins's Avatar
I'm selling the ls7 block and gonna run a iron 408
Old Jul 12, 2012 | 04:06 PM
87silverbullet's Avatar
Man, you don't have to go to that extreme. Just get a used ls2 or alum 5.3 block and let ERL or RED sleeve it. Then you have the best of 3 worlds. Bore of an LS7 and larger, strength damn near the LSX block, and the light weight of any aluminum block.
The price is probably close to what you would sell the LS7 for.
Old Jul 12, 2012 | 04:48 PM
baggins's Avatar
To what extreme??? Wouldn't that be more extreme than using a 6.0 iron block I already have? Sleeving runs $2k++ . Although I do have a aluminum 5.3 block I use for mock up:-)
Old Jul 13, 2012 | 08:23 AM
The extreme of using an iron block that will add 110lbs of weight. Plus, on a boosted or nitrous application 4.030 is recommended and 4.080 on a N/A application on an iron block.
At least if you sell the LS7 block you can damn near get the money needed to sleeve a block thru ERL. The sleeves they use are the strongest in the business and you get the bore of a LS7 and larger. Included in that price are the main studs from ARP
http://erlperformance.com/gm-ls-dry-...-block-sleeved
My next setup will be an ERL superdeck 6 bolt.
Old Jul 13, 2012 | 04:55 PM
Jimbo1367's Avatar
I don't want to be a dick and ONLY offer $1.oo more..... So ....$1001.50
Old Jul 13, 2012 | 04:59 PM
Don't have to be a dick, it was just a dick move by the other guy.
Old Jul 13, 2012 | 06:25 PM
COPO9560's Avatar
Dry sleeves for the LS7 block would cost you more than the iron 408 but you have many more head options with 4.125 bore if you are looking for big power. Did you buy an entire LS7 or only short block?
Old Jul 15, 2012 | 08:41 AM
  #32
baggins's Avatar
Shortblock only
Old Jul 15, 2012 | 09:15 AM
  #33
Were just saying to stay with the 4.125 bore because it opens up even more head options instead of going with the iron block which your max bore that would be safe in my book would be 4.070-4.080.
Old Jul 16, 2012 | 04:32 PM
  #34
speedsdaname's Avatar
Default 02 camaro stock ls7
A while back I built a stock ls7 for my 02 Camaro SS,LE with auto trans first
time on dyno with a week auto it made 460 + wrhp.So for a street car with the right cam it should be a hand full.
Old Jul 16, 2012 | 05:06 PM
  #35
KCS's Avatar
KCS
Moderator
Steve
In one of those blocks you have, the sleeve actually failed before the piston did. Aside from a little pitting, it was virtually intact.
Old Jul 24, 2012 | 12:58 PM
  #36
slowlaneblues06's Avatar
Default Interested in the LS7 block
I am getting started on a resleeved block project, and interested in using the ls7. PM me a price please.
Old Jul 24, 2012 | 01:56 PM
  #37
Roarin_8's Avatar
Originally Posted by ss454327
TSP sells the LS7 block for $2899.
You sure about that? I'm seeing 6,xxx for the short block and 10,xxx for the long block for the LS7.
http://www.texas-speed.com/c-107-427...ng-blocks.aspx
Never mind, found the LS7 block only for 2899 on the site.
http://www.texas-speed.com/c-123-engine-blocks.aspx
Old Jul 24, 2012 | 03:26 PM
  #38
8ty8 LS1's Avatar
yeah that's what sdparts is selling it for too...OP, please PM me if you want to sell that block.
