Another 402 build
NEW GM 6.0 ALUMINUM BLOCK
NEW JE PISTONS W/ 10:1 COMPRESSION
NEW CALLIES DRAGONSLAYER CRANKSHAFT 24X RELUCTOR
NEW CALLIES H BEAM CONEECTING RODS
ROTATING ASSEMBLY COMPUTER BALANCED
CUSTOM GROUND HYDRAULIC ROLLER CAM .615 .625 LIFT
MELLING HIGH VOLUME OIL PUMP
COMP CAMS BILLET ROLLER CHAIN
HARMONIC BALANCER AND FLEXPLATE
NEW LS3 ALUMINUM HEADS WITH HOLLOW STEM VALVES,
NEW SPRINGS TO MATCH CAMSHAFT
NEW GM ROLLER ROCKER ARMS
ARP HEAD BOLTS
GM LS3 INTAKE MANIFOLD
NEW GM 38LB INJECTORS
So how am I doing on the build so far? Thoughts/suggestions. I think it's gonna be pretty good but maybe some of you more experienced gear heads could give better advice.
@Che70velle - I was looking at some 42 lb. injectors but i wanted to save a little cash right now but I'll most likely bump it up to at least that once I'm back on the road and can save up and drop some cash on a set.
I'm glad to hear that I'm at least going in the right direction and not way off. Thanks guys.
The LS3 heads work best with the right cam. You showed the lift but the durations and intake valve events are really critical to making these heads work. Can you share the duration numbers?
