texas speed ls2?
Old Sep 11, 2012 | 11:01 PM
98cobrakiller's Avatar
Default texas speed ls2?
ok so im looking at the texas speed 402 ls2 hear is my question when you order the engine and you get the 24x rec wheel and the ls2 conversion do the drill and tap the knock sensors for you so all you have to do is drop it in and plug it together
Old Sep 12, 2012 | 08:29 AM
Tainted's Avatar
Are you asking if that has to be done, or of the engine comes with that already done?
If you are putting an ls2 into a ls1 vehicle then yes, you will need a 24x reluctor wheel, and opt for the ls2 conversion in the options.
Old Sep 12, 2012 | 09:36 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If you want to use the LS1 knock sensors, yes, you will need to drill and tap the holes in the side of the LS2 block for your sensors to screw in. After that, it is a very easy swap/conversion process!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 12, 2012 | 12:02 PM
im asking if texas speed will do that cause idk if i comfortable doing it myself
Old Sep 12, 2012 | 12:33 PM
Tainted's Avatar
Im sure they would. Although it really is very simple. But why use the ls1 sensors when you could just go all gen 4 stuff?
