help with an ls2!
Old Sep 26, 2012 | 12:29 PM
thefloyd1973's Avatar
Default help with an ls2!
i have a few questions.
1....i have a ls2 that we are doing a ls3 head swap on.what head gaskets should i run? factory ls2 or a set of fel pros? i was planning on either running head studs or arp bolts.
2.... could i just use aftermarket fel pro gaskets and seals for the bottom end? because i can get them as a kit or should i go with factory gm?
3.... last, we have an aftermarket cam that we need to degree. what timing chains are you guys running to degree cams? will a factory chain work? or would i be best off with a double roller?
thanks al.
Old Sep 26, 2012 | 01:07 PM
Tainted's Avatar
1.) Your choice, most people run stock gm gaskets
2.) See above
3.) Ls2 chain, or c5r chain. You dont need a special timing set to degree the cam.
Old Sep 26, 2012 | 01:09 PM
Robofuzz's Avatar
I used the GM head gaskets and the GM LS2 timing chain.
Old Sep 26, 2012 | 01:23 PM
do i need a special head gasket for the ls3 heads on the ls2 block? do you guys replace anything else when you change the chain?
Old Sep 26, 2012 | 01:36 PM
Robofuzz's Avatar
I used the stock GM L92 head gaskets. I think they are identical to the LS3. Someone can correct me if I'm wrong on that.
The only other thing I replaced was the oil pump. I installed an L92 oil pump. I don't remember the part number on the oil pump, it's been about 4 years since I did the swap.
