lq4 bolts?
im building a 550hp lq4. im wondering if i need to upgrade my head, main cap, balancer, connecting rod bolts. anything you guys recommend. im not going to be drag racing the motor. but i do plan to beat it up once in a while.
Also you should know that tightening using a torque plus angle method does not always equal torque to yield (TTY). It is merely a more accurate way of achieving a desired clamp load so it is frequently used by the factory for critical fasteners.
Everything is still bolted on from the factory except the heads and crank.
Main studs are a good move on any LS build also.
Also while I'm no expert, I haven't heard of issues with the LS factory main fasteners. The rod bolts yes, but the mains not so much.
