LS2 crankshaft replacement question
Old Nov 12, 2012 | 10:45 PM
miket2's Avatar
Default LS2 crankshaft replacement question
I am needing to replace the crankshaft in my stock 05 GTO and want to keep it stock and cheap. My question is do I need to buy a crankshaft for an LS2 to keep from balancing? Thanks
Old Nov 13, 2012 | 12:13 AM
bww3588's Avatar
Yes...the balance for a truck engine will be different. However, on a stock engine, 100 or so bucks is well spent on balancing because the stock parts are not balanced to each individual rotating assembly. You could easily gain 10-15 from a good balance.
Old Nov 13, 2012 | 12:26 AM
miket2's Avatar
The only reason I asked is the machine shop that's closest to me still has yet to bore and balance an engine i dropped off almost 3 years ago...road trip
Old Nov 13, 2012 | 02:02 AM
bww3588's Avatar
Holy ****. I'd be finding out if it's still there.
