LS2 Stock looking for some help in modify help
Old Nov 17, 2012 | 04:58 PM
mullahi's Avatar
Default LS2 Stock looking for some help in modify help
Hey.. i just wanna ask about some cams kits
i got stock ls2 corvette 2005, it has filter + headers without tune
so now im looking for daily use cam with the highest power i can make with
with cam that i can get between 400-450 whp i know thats i sounds weird and thats to much for small one and i know that cams without tuning is nothig .
i know little bit about cams but i am lookig for the best one that i can drive my car everyday with the highest power that i can make
the first choice ive seen is
1-texas speed 228R Cam 113 or 114 LSA + spring kit and push rod
2-torquer v .3 cam 111 LSA + spring kit and push rod
3-texas speed tsunami cam 111 LSA + spring kit and push rod
any more cams?
these cams i found them from texas speed
do i need :-
oil pump?
fuel pump?
injectors ?
water pump?
what size do i need for spring valve 650 or 600 is fine?
what size do i need for push rod lenght
Old Nov 19, 2012 | 08:56 AM
DACTARI's Avatar
What kind of driving do you do? Do you spend more time at low speeds, needing more torque and throttle response? Or do you want more performance at highway speeds? Do you race the car at all? If so, what kinds of races?
What size tires are you running on the rear wheels? Stock or wider than stock? How are your tires hooking/gripping with the level of power you have now?
