Installed Harland sharps, now...
Old Nov 25, 2012 | 12:44 PM
11secLS1's Avatar
Default Installed Harland sharps, now...
Thanks
Old Nov 25, 2012 | 01:15 PM
Undertow74's Avatar
little more clarification needed.....ALL you did was just swap out the rockers to HS roller rockers and that is it, then it started missing?
Old Nov 25, 2012 | 01:22 PM
11secLS1's Avatar
Yup cam was existing. Checked the plug wires, coil connections, etc
Old Nov 26, 2012 | 07:56 AM
11secLS1's Avatar
Anyone?
Old Nov 26, 2012 | 09:21 AM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Maybe a loose wire harness somewhere?
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Nov 26, 2012 | 09:27 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Are they stock ratio rockers?
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 26, 2012 | 10:12 AM
87silverbullet's Avatar
I did the same thing you did to the LS2 in my 06 vette. I changed the pushrods (7.400) and put on Harland Sharp rockers and the car did the same thing yours did.
I noticed my stock pushrods were shorter than the 7.400 Comp's I put in. I also had the 1.8 rockers too. I think it all added up to too much and was hanging the valve open causing the misfire.
I took it all off and sold it to a buddy of mine. Put the stock stuff back on and sold the car a few months later.
Old Nov 26, 2012 | 11:03 AM
11secLS1's Avatar
Yes, stock ratio.
Old Nov 26, 2012 | 11:26 AM
ss4chad's Avatar
Pull the plugs, sounds like one of them is cracked.
Chad
Old Nov 26, 2012 | 11:27 AM
Ohio Bird of Prey's Avatar
Sounds as though the PR's are now too long with the new RR's.
Old Nov 26, 2012 | 11:36 AM
Sales2@Texas-speed's Avatar
Wrong pushrod length (too long) for the combo with those rockers.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 26, 2012 | 11:56 AM
11secLS1's Avatar
I'm going to check the pushrods length on Friday. Any thoughts on where I should expect to be with regards to PR length?
Old Nov 26, 2012 | 03:11 PM
Hard to say without measuring....do you have a pushrod length checker tool?
__________________
Old Nov 27, 2012 | 05:10 AM
Slowhawk's Avatar
LS1Tech Sponsor
You have to check pushrod length with any rocker change. They are too long,do not crank it anymore till it's fixed.
Old Nov 27, 2012 | 10:29 PM
ls7powered's Avatar
push rods too long for sure!!!!
