370 build questions
Old Dec 5, 2012 | 09:07 PM
stockblock85_22's Avatar
Default 370 build questions
Im sure all of this may be covered in here somewhere but i dont see it so ill ask... Im lookin to build a 370 with a iron 6.0 block. The block has to go .30 over so i will be buying a set of pistons. I will be using l92/ls3 heads. Here are my concearns
1. Would like to get 11-11.5 : 1. What piston do i buy to achieve this with a valve relief big enough to still run a healthy cam? How much will the heads need milled if any
2. Arp bolts & stock rods... I have heard something needs to be done
3. Building on a budget, best piston for the $$?? Where to buy??
Will be using a ls3 intake also. Lookin to make 475 through a stalled auto... Is this reasonable? Im just worried more than anything about what piston i can run to get the compression i want. I will have pat g spec a cam and dont want to be limited on it due to ptv clearance. Any help is appreciated.
Old Dec 6, 2012 | 12:11 AM
bww3588's Avatar
Same setup I have,
My setup is
.030 over 6.0 decked to 9.2155
K398x3 pistons for a 6.125 rod.
Scat 6.100 rods
Stock crank
Ls3 heads milled .045 with a .040 gaskets giving me 11.3:1 compression.
Stock ls3 intake and rails.
Hope this helps. Pm me if you have any more questions or look under my profile for my build thread
bww3588's Avatar
Oh and an EPS 230/242 .603/.605 113 cam
