Head studs or bolts?????
Old Feb 2, 2013 | 01:16 AM
Machine-Master's Avatar
I did mine to 30lbs on the first pull with ARP lube under the washer above the washer and on the threads, then went for the second pass at 65lbs, the smalls I just made hand tight but using a Mac inch pound torque wrench I went to 244 in-lb
