DOD delete front cover
Old Dec 17, 2012 | 10:54 AM
TurboMonte100's Avatar
Default DOD delete front cover
I am deleting the dod. I know the LS2 cover is shorter and guys use it , but Do I have to the change the front cover? Is the sensor in the same spot? Is there an actual reason for swapping other than looks?
Old Dec 17, 2012 | 11:56 AM
85MikeTPI's Avatar
DOD systems also run VVT systems which have a large phaser on the front of the cam, necessitating the thicker front cover. If you just delete DOD and retain VVT, you don't need a new cover. If you remove both DOD and VVT and put in a 3-bolt or standard cam&gear, you need to put on the thinner cover so the crank sensor can move closer to read the cam gear.
Old Dec 17, 2012 | 12:29 PM
Thank you, thats what I needed. I'll order a new cover. I take it the sensor will work?
Old Dec 20, 2012 | 08:46 AM
Fast6.3's Avatar
I have a 2010 siverado I removed dod and used the same front cover no issues with a 3 bolt cam
Old Dec 20, 2012 | 09:17 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
DOD deleting does not change the front cover. Deleting VVT does.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 20, 2012 | 09:24 AM
Thanks. I just got home from picking up the cover at the dealer, only to discover I could have used the original.
Old Dec 22, 2012 | 08:46 AM
Zfan's Avatar
I just purchased the VVT delete kit from TSP, same thing for me too. The cover is the same and I have the same upper gear in my spare parts box. I guess I'll just ship it back for a refund..oh, well!
