correct cam sprocket?
Old Dec 27, 2012 | 12:39 PM
bugy's Avatar
Question correct cam sprocket?
hey guys, this is a 5.3L IV gen, i'm rebuilding it, just got confused about crank sensor and cam gear, crank has 24 tooth reluctor wheel (black sensor) with 1x cam sprocket, into a colorado 2004, using 2002 truck pcm, i'm almost sure cam sprocket is correct with this setup, when i tried to fire it up, it just throws explosions as it were out of time, am i using correct cam sprocket? should i change it for 4x one?
Old Dec 27, 2012 | 12:47 PM
Gray86hatch's Avatar
The 1x is for the 24x crank. As long as the ecu matches the engine and the cam is degreed correctly you should be fine
Tim
Old Dec 27, 2012 | 01:29 PM
bugy's Avatar
I still have some doubts about pcm just found it is a 411 pcm (12200411)
http://www.gmtruckcentral.com/articles/12200411.html
im using painless wire harness 60217, made a change in cam sensor conector with 2 cables just inverted them to make sensor work, i guess something may be wrong around there...
engine and cam are well on time, followed harness instructions as mentioned, everything is right i guess...
