Lunati single bolt cam
Old Jan 7, 2013 | 02:23 PM
newschool72's Avatar
Default Lunati single bolt cam
Anyone had any experience with the lunati hi lift cams. Im looking at the 21460704 for my stock cube LS3 w stock heads and a vic jr intake. Ive been throwing the idea around on a possible stroker or heads/cam change, but money is going to be tighter than I thought . The specs are 651/651. 227-239 at .050 on a 112/108. I dont want a max effort cam, but a streetable but stout 11 second street cam. Whatcha think?
Old Jan 7, 2013 | 05:44 PM
ringram's Avatar
looks reasonable. You will need some good springs on that.
Old Jan 7, 2013 | 06:05 PM
Im running a Comp LSR269 in the LS3 now (219-235, 607-621 on a 113) and have the Comp 26926 Dual springs on the heads now. If I remember right ,they are good to .675 and are designed to keep up with the LRR lobes. Do you think they will work out with Lunati Hi-lift lobes?
