Engine OIL cooler...........
Old Jan 11, 2013 | 10:31 PM
LS6427's Avatar
Default Engine OIL cooler...........
Anyone use this one...?
Also, for a 390ci iron block, will this thing really drop oil temps and keep them lower than if I didn't have it....?
http://www.summitracing.com/parts/hda-1040
Old Jan 12, 2013 | 08:19 AM
RAMPANT's Avatar
If you have a full length header on it that adaptor will never work, neither will the Kateck, LPE, Canton, Moroso or Hamburger will leave the fittings hanging way too low or do not fit. This is assuming you are talking an F-Body.
If the F-Body is stock manifolds, they work, but are tight.
I modified the Canton for mine.
For my cooler I went with a Ron Davis 14 plate oil to water cooler.
