crank size?
I really don't care that much, it your car and project, but it sounds like a lot of feather ruffling over the truth.
Like I said, I have no knowledge of how the conversation went down. however, from they way the posts read, it seems like things got down the wrong road aweful quickly.
I also forgot to mention this engine will be an N/A engine and will hardly ever see a drag strip. It'll be used for weekend cruising, driving in the mountains or on the coast, car cruises and maybe some autoX and/or road course.
Also, 4.020" most likely wouldn't be a problem on a street driven LS2. We're talking .010" off the cylinder walls. It's not like you're putting a blower on it.
The more I look, I don't see a shelf 3.900" stroke piston available. Those would most likely be custom.
Also, most piston manufacturers will set a custom compression depth for 50 bucks over the price of 8. So custom cd pistons wouldn't be too much of a shock to your wallet. Just get 6.125 rods, and start with a piston for a 4 inch stroke and add .050 to the compression depth.
You may get lucky like I did and be able to deck your block a little and run a shelf piston. I'm running shelf pistons in my 370 for a stock stroke and 6.125 rods and I'm running a 6.100 rod. Just some time with the math can save you money.
https://ls1tech.com/forums/showthrea...741&styleid=25
I also have a 403 LS2 with K1 crank & rods that I haven't run yet. It's more of a long term project at this point...lol
