Lost.
Old Feb 21, 2013 | 08:11 PM
longcut's Avatar
Default Lost.
I bought an LS1 from craigslist with a spun rod bearing for $400.00. Had it pressure checked (it was good.). I had it honed .010 over and the crank turned .020/.020 new cam bearings and cleaning was $477.00. So I have $877.00 in a block and crank. The rods can't be re-sized and the pistons are worthless. So If Im going to build a bottom end, should I build one for a a bigger block?
My reason for posting in the gen IV section is because I'm thinking of selling and starting over with a 6.0 Iron block. I figure if Im going to have to build the bottom end anyway might as well build a bigger displacement block. If I had the cash I'd have a 5.3 re-sleeved to the LS3 bore but that's like 2k plus 5.3 core.
I plan on keeping my heads for the 6.0. Can I use the LS1 turned crank in a 6.0?
Thanks. Here is a link to my CL ad. Criticism is welcome
http://fayar.craigslist.org/pts/3585379629.html
Old Feb 21, 2013 | 08:13 PM
Tainted's Avatar
I think you should go for the 6.0 for sure, and yes you can reuse the crank
Old Feb 21, 2013 | 11:17 PM
Blackpanther99's Avatar
Go for the 6.0, more power!
Old Feb 22, 2013 | 02:10 AM
bww3588's Avatar
.010 is a lot over on stock sleeves..007 over is about max on the 00+ blocks. Hopefully it holds up.
Old Feb 22, 2013 | 06:37 AM
longcut's Avatar
One of my LS books says GM does not recommend anything over .010. Machine shop says no problem.
Old Feb 22, 2013 | 07:36 AM
bww3588's Avatar
It's your engine...hopefully it lasts for whoever buys it.
Old Feb 22, 2013 | 08:04 AM
87silverbullet's Avatar
Yeah, .010 is alot on an LS1 block. It's the reason why the stock bore is 3.898 and the only shelf piston that I know of is 3.905 which would put you .007 like bww3588 said. For .010 over you would need a 3.908 piston and I don't know of anybody who makes one.
If you are going to go 6.0 I would take the iron block out to 4.065 so you can use an LS3 rotating assembly or try to find an LS3 block on here or craigslist.
Old Feb 22, 2013 | 08:16 AM
bww3588's Avatar
That was going to be my next post, but I figured I would save the argument this time.
Old Feb 22, 2013 | 08:38 AM
Yeah it gets old after awhile, but you have to remember, we were learning at one time also.
Old Feb 22, 2013 | 09:44 AM
bww3588's Avatar
I just hate to see people learn the hard way.
Old Feb 22, 2013 | 09:47 AM
Tainted's Avatar
I dont, it makes for entertainment
Old Feb 22, 2013 | 10:13 AM
KCS's Avatar
KCS
Moderator
The difference between .007" and .010" is about the thickness of a plain sheet of notebook paper, divided in half and that's .0015". That's not gonna make the engine any less reliable.
The biggest setback is finding a 3.908" piston, which I'm pretty sure is a shelf piston that Mahle makes, so that's not really a big deal either.
Nearly $500 for that little amount of machining is a raping though, I wouldn't expect to recover your money by selling the stuff. You may be lucky to sell it all for $600.
Old Feb 22, 2013 | 10:20 AM
See, learn something everyday. Amazon sells that piston.
