R07 CGI block
Old Feb 26, 2013 | 12:48 PM
96lt4c4's Avatar
There was a toyota version in the stands at Daytona over the weekend, may have been able to score that one....
Old Feb 26, 2013 | 01:31 PM
4thgenRookie's Avatar
http://www.texas-speed.com/p-578-gm-...ls2-block.aspx
Found one, and I could definitely work with that price
Old Feb 26, 2013 | 01:36 PM
[QUOTE=96lt4c4;17182595]There was a toyota version in the stands at Daytona over the weekend, may have been able to score that one....
lmao him starring at the firewall was priceless
Old Feb 26, 2013 | 03:09 PM
87silverbullet's Avatar
Man, screw that. If you are going to sleeve it like tainted said you can can scour on here for a 5.3 aluminum block. They are cheaper and can be sleeved just like an LS2 block. I bought 2 of them on here for $300 a piece.
If you are going to stay N/A you can get an LS7 block cheaper than that and already have a 4.125 bore.
Old Feb 26, 2013 | 03:31 PM
1bdbrd's Avatar
Originally Posted by Tainted
Yea you can use any of the aluminum ls blocks, the sleeve will determine the size of your new bore 6.0 blocks are plentiful and fairly cheap making them an easy target.
The cheaper starting point is the aluminum 5.3. I have seen them on ebay for less than 300 bucks and I have never seen a 6.0 block go for that cheap.
With the aluminum 5.3s you just have to be careful to get a rwd version as the LS4 front wheel drive version is cast different and I don't think can be mated to a rwd transmission.
Old Feb 26, 2013 | 06:34 PM
Thanks guys but I think I'm going to stick with the LS2 all input is appreciated
Old Feb 26, 2013 | 11:22 PM
May I ask why when we have posted a cheaper viable option?
Old Feb 27, 2013 | 03:58 AM
I don't want to risk spending the money and getting the wrong block as stated earlier with the whole front wheel drive situation also I'm not sure if I want to change this block being unsure if it would alter the type of application I'm going for being a sleeved 427 but I'll look more into it
Old Feb 27, 2013 | 07:51 AM
In that case you can get them already done from ERL so you won't get the wrong one. They stock them, just give them a call.
Old Feb 27, 2013 | 08:01 AM
LS1MCSS's Avatar
You won't have any problem telling the difference in the blocks. The FWD version has a different bolt pattern for the bell housing. It's easy to see the difference.
Old Feb 27, 2013 | 07:33 PM
midnightbluS10's Avatar
I like where your going
I don't. That seems like a lot of unnecessary expenses just for 600rwhp.
You could do that with a junkyard 4.8L build, a nice size turbo, and meth injection.
Old Feb 27, 2013 | 08:19 PM
  #32
I checked out their sight and all I could really see were straights, they did have a pretty nice application (at least I thought so) called the superdeck that could work well with sleeves
Old Feb 27, 2013 | 08:22 PM
  #33
Ok cool thats what I was mainly worried about, checked out a couple identical swaps on youtube a lot of people actually use the 5.3L
Old Feb 27, 2013 | 08:23 PM
  #34
Going for n/a
Old Feb 27, 2013 | 08:32 PM
  #35
Wnts2Go10O's Avatar
[QUOTE=4thgenRookie;17182702]
it was a hendrick motor. aka chevy.
Old Feb 27, 2013 | 08:35 PM
  #36
Wnts2Go10O's Avatar
i thinnk most of the point of the CGI block is weight. sure, you can do the same with a truck block. but a bare truck block is ~250 lbs
Old Feb 28, 2013 | 08:03 AM
  #37
It's actually a little less. One of the mods (Reckless) weighed all of the ls blocks and the 6.0L iron weighed 216. Here is a link.
https://ls1tech.com/forums/generatio...ls-blocks.html
Old Feb 28, 2013 | 12:59 PM
  #38
Wnts2Go10O's Avatar
O_o huh, learn somethin new everyday
Old Feb 28, 2013 | 02:28 PM
  #39
It's all good. No matter how you look at it, its still a heavy SOB
Old Mar 5, 2013 | 02:27 AM
  #40
That was the whole part I was hung up on "Weight" I wasn't specifically comparing it to any other blocks, it just seemed like a nice advantage to have in a street/strip car
