416 help please
Right now the shop is changing my engine mounts, adding two B&M fan Trans cooler, and a Trans/diff brace.
Any inputs would be greatly appreciated
I dont think the cam is your issue... and there is no reason for you to be on speed density at all, ever. MAF everything... the e38 is 1,000,000 times better then the old ls1 pcms.
We had a real nasty random lean spike that we chased for months. It just showed up one day and I had the world look at my tune and scans. We changed everything electronic, including the engine wiring harness and still could not get rid of it. For some reason the 80th time we purged the tune and uploaded the new tune the spike was gone. It also destroyed three 6L80 transmissions in those 3 months. This car has alway been a tuning pain in the butt.
Back to the problem at hand, I want to find some more power. SDPC made some big claims on the heads I have so where is my 550rwhp?
Gear ratios:
First:
4.02
Second:
2.36
Third:
1.53
Fourth:
1.15
Fifth:
0.85
Sixth
0.67
I know I need to do something but I am not 100% sure what I need to do the car should make another 40rwhp. As the car sits it is 505-510rwhp.
Video
I did not do the underdrive pully because the car already runs hot and will over heat in traffic. I have the biggest radiator and dual fans. They are installing twin B&M Trans coolers with therm controlled fans right now. When it gets out of the shop I am getting the hood vented also.
My Hinson front motor mounts split so they are replacing those and installing a Trans/rear diff brace I had made in CA. For some reason you can only buy them for standards.
My camshaft knowledge is basic, I have no idea about ramp rates and things like that.
The car runs the 1/8th in 6.6-6.7 @ 101-103mph with a 60' of 1.42-1.46 with the old 3000rpm vigilante stall
I have only made a few passes with the new stall 3800rpm circle -D triple disc. It is going to take some adjustments to get my traction back and I need to figure out the best rpm to load it. My 275/45-17 Hoosiers are giving me traction at 16psi cold but the car is rebounding and blowing that traction away
