Ls2 misfire trouble Help!! please
I have a 2006 Gto with 57,000 miles and I've been fighting a misfire problem for a while now.This is the story...from what I remember it didn't misfire before my tune or at least I didn't noticed it. Car seemed to run fine...then i had a bad sputtering and a rough idle like it was cammed about a month or so later with a CEL that I scanned ..it was a bad o2 on bank 1 sensor 1 ...which i swapped with bank2 sensor 1 and it followed it there so i replaced bank 1 sensor 1 with new o2 sensor. So after that i still have a rough idle and when under load i get little jerks im guessing misfires here and there with a flashing CEL.I dont get a smooth acceleration. The mods are otrcai , jba headers and cat less midpipes msd spark plug wires and NGK tr55 spark plugs. I've pulled the spark plugs often to check and they look like they are fine. I also had a leaking vavle cover gasket but on opposite side but I replaced both.
Things I've done to trouble shoot are I've switched plugs around, coil packs around, swapped injectors ,spark plug wires and a compression check. The misfires always stay on cylinder #4 never moves so I'm thinking all the parts are fine
Compression #'s are
Cyl # 1 (190)
Cyl #2 (195)
Cyl #3 (189)
Cyl #4 (186)
Cyl #5 (189)
Cyl #6 (191)
Cyl #7 (190)
Cyl #8 (190)
Whats steps should I do next?
Do you thinks its the tune?
Ive also tried spraying around starter fluid for vaccum leaks didnt see any real noticeable changes in engine running.
Should i just pull the intake manifold for fun to check it out?
Thanks for the help in advance and sorry i did this from my phone.
