HUC lobes
Brain Tooley racing.
The HUC lobes are good to keep the valve train under control. Also helps parts live longer.
Comparable XER is 287@.006"/238@.05"/159@.200" with .356 lobe lift so 1.7 ratio is .605 lift.
HUC lobe should make more power, they're also faster off the seat than LsL lobes and more stable.
I think they work. IIRC they were designed for marine applications that tend to run at elevated rpms constantly.
I wonder what lobes he used on my current build?? I have to ask him.
LS Fest True Street Winner
FTP TURBO LS FOX LS FEST - YouTube
Need to show this to Jamie Mattingly...lol that thing is insane.
Not bad for less than 400 lbs open spring pressure and stock rockers!
#13161, 290 @ .006", 238 @ .05", 159 @ .200", .615" lift.
#13162, 294 @ .006", 242 @ .05", 162 @ .200", .615" lift
#13163, 298 @ .006", 246 @ .05", 166 @ .200", .615" lift.
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
HUC Lobe Chart:
13045, adv 285, 231@.050 , 149@.200 , lobe lift .352 .598
13047, adv 289, 235@.050 , 154@.200 , lobe lift .359 .610
13048, adv 291, 237@.050 , 156@.200 , lobe lift .359 .610
13049, adv-294, 239@.050, 157@.200, .610"
13050, adv 294, 239@.050 , 158@.200 , lobe lift .365 .621
13051, adv-298, 243@.050, 162@.200, .627"
13052, adv 302, 247@.050 , 166@.200 , lobe lift .372 .632
13053, adv 306, 251@.050 , 169@.200 , lobe lift .372 .632
13054, adv 310, 255@.050 , 173@.200 , lobe lift .372 .632
13056, adv 318, 263@.050 , 181@.200 , lobe lift .372 .632
13057, adv-322, 267@.050, 184@.200, .632"
LXL Lobe Chart
13155, adv-266, 214@.050 136@.200, lobe lift .350, .595
13156, adv-270, 218@.050 139@.200, lobe lift .352, .598
13157, adv-274, 222@.050 143@.200, lobe lift .354, .602
13158, adv-278, 226@.050 147@.200, lobe lift .356, .605
13159, adv-282, 230@.050 15@.2001, lobe lift .358, .609
13160, adv-286, 234@.050 155@.200, lobe lift .360, .612
13161, adv-290, 238@.050 159@.200, lobe lift .362, .615
13162, adv-294, 242@.050 162@.200, lobe lift .362, .615
13163, adv-298, 246@.050 166@.200, lobe lift .362, .615
13164, adv-302, 250@.050 170@.200, lobe lift .362, .615
13165, adv-306, 254@.050 173@.200, lobe lift .362, .615
13166, adv-310, 258@.050 176@.200, lobe lift .362, .615
13167, adv-314, 262@.050 179@.200, lobe lift .362, .615
13168, adv-318, 266@.050 182@.200, lobe lift .362, .615
13169, adv-322, 270@.050 186@.200, lobe lift .362, .615
13170, adv-326, 274@.050 189@.200, lobe lift .362, .615
EPS Lobe Chart:
13116, adv 271, 222@.050, 144@.200 , lobe lift .351 .5967"
13117, adv 275, 226@.050, 148@.200 , lobe lift .352 .5984"
13118, adv 279, 230@.050, 151@.200 , lobe lift .353 .6001"
13119, adv 283, 234@.050, 155@.200 , lobe lift .354 .6018"
13120, adv 287, 238@.050, 159@.200 , lobe lift .355 .6035"
13121, adv 291, 242@.050, 162@.200 , lobe lift .356 .6052
LSL Lobe Chart:
13014, adv-265, 215@.050, 139@.200 .604"
13015, adv-269, 219@.050, 143@.200 .607"
13016, adv-273, 223@.050, 147@.200 .610"
13017, adv-277, 227@.050, 151@.200 .614"
13018, adv-281, 231@.050, 154@.200 .617"
13019, adv-285, 235@.050, 158@.200 .621"
13020, adv-289, 239@.050, 162@.200 .624"
13021, adv-293, 243@.050, 166@.200 .624"
13022, adv-297, 247@.050, 169@.200 .624"
13023, adv-301, 251@.050, 173@.200 .624"
13024, adv-305, 255@.050, 176@.200 .624"
13025, adv-309, 259@.050, 180@.200 .624"
13026, adv-313, 263@.050, 183@.200 .624"
13027, adv-317, 267@.050, 187@.200 .624"
13028, adv-321, 271@.050, 190@.200 .624"
13029, adv-325, 275@.050, 193@.200 .624"
*Thanks Brian, I Updated the list.
