custom speced comp cam
Old Apr 9, 2013 | 10:11 AM
newschool72's Avatar
Default custom speced comp cam
Guys ,momma rabbit finally gave the OK for a custom speced cam for my LS3 and I found the specs for a cam comp recommended for my setup.
Back ground on the setup is....3300lbs 72 Camaro, 2004R trans,2200rpm lock up convertor, 3.42 rear gears, 26in tire, stock LS3 with Vic Jr single plane intake and Fast EZ EFI, 1 7/8 longtube headers.
The car also has AC and big caliper power brakes on all four corners.
I want all the power I can get WHILE keeping good drivability and enough vacuum for the brakes.
The custom specs I got from comp a year ago(that I lost and just found,lol) are XER lobes w 228/242 at .050, 588/610 lift on a 110+2.
Chime in gurus of the lobe!
Old Apr 9, 2013 | 10:56 AM
I forgot to say I have a comp LSR 269 cam in the engine now. It specs at 219/235 at .050, 607/621 lift on a 113. I have the comp 26926 dual springs on the heads now, so I should be fine on valve springs.
