ERL Superdeck II Build
Old Oct 17, 2013 | 10:40 AM
blackonblacksls's Avatar
I understand they Are heavy in comparison but you also said it was 4400lbs and there is just no way if it's a NA build with an aluminum block on 18inch wheels. Especially if your average size and weight.
Old Oct 17, 2013 | 03:37 PM
Momentum's Avatar
That was a swag as I haven't had it corner balanced since making so many changes.
Since you can't see much of these after installation, here are some pics of the 5 stage pump and oil pan from Dailey Engineering.
Attached Thumbnails ERL Superdeck II Build-pan1-small-.jpg   ERL Superdeck II Build-pan2-small-.jpg   ERL Superdeck II Build-pump1-small-.jpg   ERL Superdeck II Build-pump2-small-.jpg
Old May 11, 2014 | 12:29 PM
Momentum's Avatar
Between finding shop availability and gathering up hoses and fittings, we finally got the dry sump installed. We elected to go with a tall Z06 style tank. Since this is an a/c delete, we cut a hole in the wheel well and put it where some of the HVAC stuff was in the back left of the engine bay. We also had to cut a bit off the side of the tank for wheel clearance but it still looked good.Here are some pics. If I had to do over again, I would probably just put the tank in the trunk and all those long lines would act as my oil cooler.
The pump sits where the a/c compressor used to sit.
Attached Thumbnails ERL Superdeck II Build-img_20140511_115058_558.jpg   ERL Superdeck II Build-img_20140511_115557_329.jpg   ERL Superdeck II Build-img_20140511_115619_209.jpg   ERL Superdeck II Build-img_20140511_115651_685.jpg
Old Mar 5, 2016 | 12:59 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Default Cam Specs
Momentum,
How are you enjoying your ride?! Haven't seen a post in quite
A while. I was hoping you would share your cam specs
From your 603/599 build presuming you haven't changed it
In the last 1 1/2 + Years, also did the Dry Sump have any
Effect on the power numbers.
Thanks
Old Jul 12, 2017 | 06:39 PM
bryan nena's Avatar
Default Fyi
The thing you keep referring to as a motor is actually a internal combustion engine and not a motor just saying
Old Jul 12, 2017 | 06:46 PM
SSSTANG#1's Avatar
motor
[moh-ter]
Spell Syllables
Examples Word Origin
See more synonyms on Thesaurus.com
noun
1.
a comparatively small and powerful engine, especially an internal-combustion engine in an automobile, motorboat, or the like.
2.
any self-powered vehicle.
3.
a person or thing that imparts motion, especially a contrivance, as a steam engine, that receives and modifies energy from some natural source in order to utilize it in driving machinery.
4.
Also called electric motor. Electricity. a machine that converts electrical energy into mechanical energy, as an induction motor.
Old Jul 12, 2017 | 08:00 PM
slogo's Avatar
Well this is one helluva first post.
Old Jul 12, 2017 | 08:51 PM
He's sounding a lot like Lance at PanteraEFI... lol
(he just got on someone for the same exact reason..)
Old Jul 21, 2017 | 03:41 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
And yet we call it Motorsports....
__________________
Old Jul 21, 2017 | 06:51 PM
There ya go.......
