5.3 heads on a 6.6 stroker
Old Apr 21, 2013 | 03:47 AM
Chev133's Avatar
Default 5.3 heads on a 6.6 stroker
Hi, I brought a set of 2.5 5.3 heads from tsp for my 5.3 silverado and now am adding a 6.0 L block with a 4 inch stroker crank. Will this work ? It will have -10cc pistons with 11.5 comp. it will have l/t headers, lsxrt intake, 102mm nick William t/b, volant cold air intake. Also, will my 36 lbs injectors be ok ?
Old Apr 22, 2013 | 06:50 AM
96 Comp T/A's Avatar
Sure it will work. It will probably end up with killer torque but give up a little on top to some of the other head offerings out there. NOt sure on the injectors, if you already have them, I would run them and see what the duty cycle looks like.
