Megadeath Cam
Old Jun 13, 2013 | 12:55 PM
jared879's Avatar
Post Megadeath Cam
So i have this chance to get the megadeath cam for a pretty good deal and i just did a lq4 6.0 swap in my trans am and id like to have a cam in it again. has any body ran into problems with this cam and how well the cam will work with the 317 heads? Lots of input please
Old Jun 13, 2013 | 12:58 PM
redtan's Avatar
Will be a dog anywhere under 5000rpm. But after that it will SCREAM.
Old Jun 13, 2013 | 01:07 PM
jared879's Avatar
I under stand that, so I got me a 9 inch with 4.10! I hope it still won't be a dog...so is the cam okay with those heads?
Old Jun 13, 2013 | 01:19 PM
redtan's Avatar
Yes it will be fine with those heads.
Old Jun 13, 2013 | 01:44 PM
newschool72's Avatar
Better have some good rod bolts if the cam doesn't come in till 5K, unless you shut it down at 7K or less. 1000 to 5000 is a long time to wait, just to change gears 1800 rpms later. It will get a lot of attention idling in the parking lot though, LOL.
Old Jun 13, 2013 | 02:12 PM
Know_It_All's Avatar
There's a reason you got a good deal on that cam.
Do you realize what your compression is with an LQ4 and 317 heads?
Old Jun 13, 2013 | 02:33 PM
jared879's Avatar
yea i understand on that now after looking over it more, i was gunna add a 100 shot to it too, depending on how i felt haha and as far as the compression no i dont...i know how idiotic that sound haha...
Old Jun 13, 2013 | 03:42 PM
jared879's Avatar
and i was also thinking about doing a ls3 top end..
Old Jun 14, 2013 | 07:51 AM
The compression will be about 9.4:1 and the cam is 244/242 in duration. That combo would suck.
Even with LS3 heads, you're still only looking at about 9.7:1.
Old Jun 14, 2013 | 07:57 AM
redtan's Avatar
Think about it this way...how expensive are cams anyway? A few hundred bux?
In order to save a measly $200 you're willing to compromise the driveability of you car?
Why not sell that cam on here for a profit most likely (if you got a good deal on it) and then spend some $350 for a brand new cam that will work much better with your setup. Mill the heads a bit to gain some compression back and watch your car be a lot more fun.
Old Jun 14, 2013 | 08:49 AM
jared879's Avatar
That's very true I agree with you 100% after doing more research I have a couple of buddies with GTOs and vettes I'm sure ill find somebody. Thanks alot! This helped me alot!
Old Jun 14, 2013 | 10:36 AM
Spot on !!
Old Jun 14, 2013 | 02:49 PM
handyandy496's Avatar
perfect advice....but get a blower. HA HA HE HE
