6.0 build questions
So I'm wanting to do a lq9 swap. I want to make 400hp to the wheels, I also plan to add a 100-150 shot. I have a few questions.
Can I do that with the stock 317 heads( Ill use my ported ls6 intake)? Or should I swap to an ls3 top end?
I'm thinking vrx 4. But open to suggestion on cams
what all will I need to swap this motor to my Camaro?
And this car will be a weekend cruiser/ Friday night street fighter.
So I want it to be some what street able.
Thanks for you advice.
Justin
__________________
If budget is tight, you can just do a basic valve job and milling on the 317s.
my friend ported can port mine for cheap
