head gasket question
Old Jul 31, 2013 | 04:12 PM
ws6guy27's Avatar
Default head gasket question
Ordered 2 gaskets. Wanted .054 but when I recieved I got .054 snd .051... should I get a return?
Old Jul 31, 2013 | 08:03 PM
Blackpanther99's Avatar
For a LS1? Any mods? Aftermarket heads?
Old Jul 31, 2013 | 08:34 PM
thendawg's Avatar
So you got 2 different gaskets? Youll def want to return the wrong one as that will cause your comp on one side to be slightly diff then the other. Even at .003" its still not worth it when you dont even have anything put together yet.
Old Aug 1, 2013 | 01:47 AM
ws6guy27's Avatar
Yes its a built erl block ls2. And all pro heads ls7. I was told there was a typo. im really paranoid. I didnt know if it would make a big difference but I am a little worried about it.. sucks bc I paid 110 a piece for these mls gaskets... I have a bore of 4.155 and there 4.160 s9 basically perfect size.. I been having trouble trying find a good gasket that wont give my heads or block ring grooves from the metal ring in the gasket
Old Aug 1, 2013 | 09:23 AM
xBoostx's Avatar
I would call them up see what the tech says must likely he will exchange one to have both the same.
